Battery Pack for iPad
surfymark
Established Member
Hi there!
I have used a TechNet battery pack for my iPhone for a while now and find it really good. However it is no good for the iPad (iPad 1).
I could really do with a battery pack that I can plug a USB cable into to charge other items as well as the iPad.
I don't use this sort of thing that often so wanted something super cheap. My iPhone one was about £10, so looking to spend not much more than that if possible.
Any ideas? Recommendations?
cheers
M
billycan
Established Member
I think you'll struggle to find anything that will give an Ipad a significant power boost for £10.
Have a look at Chinavasion.com - they have a useful 9000 mAh charger for £21, plus other options.
Edited to add;
They also have a 5000mAh charger for £11. Given that the ipad battery is 7000mAH the charger should give it a worthwhile boost. The bigger version should fully charge it.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
