Battery Life
How often do you charge your player's battery?
  • More than once a day
    Votes: 2 3.9%
  • Once a day
    Votes: 8 15.7%
  • Once every other day
    Votes: 7 13.7%
  • Once every three days
    Votes: 8 15.7%
  • Once every four days
    Votes: 3 5.9%
  • Once every five days
    Votes: 2 3.9%
  • Once every six days
    Votes: 1 2.0%
  • Once every week
    Votes: 7 13.7%
  • Less than once a week
    Votes: 5 9.8%
  • Less than once a fortnight
    Votes: 8 15.7%
  • Total voters
S
shadowritten
Thought I'd conduct a poll to see what we're all getting from our players in terms of juice. I'm hoping this will be more helpful to people than simply reading conflicting reports online about how many hours each player's battery is supposed to last per single charge (which is broadly meaningless anyway).
If you vote, it would be helpful to post in this thread as well, giving answers to the following as accurately as you can:
1) What player do you own?
2) How long have you owned it?
3) Does it have an internal or removable battery?
4) If removable, how old is the battery?
5) What format/bitrate do you use most?
6) How loud do listen to music on your player (1= Very low; 10= Very loud)
7) For how long do you listen to your player on average each day?
8) How often do you charge your player's batteries (be as accurate as you can)
Here are my answers:
1) Panasonic SL-CT710 CD/MP3 Combo Player
2) About four months, if memory serves correctly?
3) It has two types of removable battery: 2 x 'chewing gum' variety + 2 x AA via attachable pack
4) I'm guessing the 'chewing gum' batteries that were supplied with the player are probably a bit older than the unit itself. The AAs are about 6 months old and are rechargeable.
5) I only use standard CDs, so equivalent to using uncompressed WAV.
6) My volume goes from 1-25, and I listen around 16-20 - so that's about 6-7 on a scale of 1-10.
7) Between 4 and 7 hours per day, five days' a week.
8) About once every 9-10 days, including the external AAs.
Over to you ...
K
KJ_Palmer
My HD5 seems to go for more than a week without charging, though perhaps I'm not a particularly heavy user, perhaps 1-2 hours a day on the commute...
[Edit - details:]
1. Sony NW-HD5h (30GB) ATRAC/MP3 player
2. Owned approx. 6 months
3. Removeable Li-Ion battery
4. 6 months (original which was bought with player - also have a backup spare)
5. mostly 192 kbps (some @256 & 352k though) ATRAC3+ with a very few MP3s
6. 5/10 (top AVLS setting = 14/30 - but vary with inline earphone volume control)
7. 90 mins a day (usually in shuffle mode) 5-7 days a week
8. Probably every 10-12 days, sometimes seems a whole fortnight...
Del Boy Smiffy
1) Ipod video 30GB
2) About a month
3) Internal
4) N/A
5) 99% @ 320kbps
6) 6-7 i guess
7) At least from 8am to 5pm
8) Every time i get back from work
drlau9
Sony HD5 Black
I've had it for around 9 Months
Re - mov - a - ble
As old as the player
192kb/s atrac 3 plus
About 3 ( I have Closed circuit E5c's ) 3 is enough
8 - 9 hrs
Exactly every sunday at 3am
Dr.
robby***
1) Sony A1000
2) Owned it three weeks
3) Removable battery
4) Battery three weeks old
5) What format/bitrate do you use most? ATRAC3+ 160kbps
6) Volume is around 4/10
7) For how long do you listen to your player on average each day? Five hours a day
8) Recharge battery every 3 days
S
shadowritten
drlau9 said:
Re - move - a - ble
Before attempting to correct the spelling of a professional writer, I suggest you check a dictionary ... there's no 'e'! :D
Thanks for contributing to the thread, though. Much appreciated.
rigger123
1) What player do you own? NW-HD3
2) How long have you owned it? just over a yaer
3) Does it have an internal or removable battery? internal
5) What format/bitrate do you use most? atrac3 132kbps
6) How loud do listen to music on your player? 5
7) For how long do you listen to your player on average each day? <1 hour
8) How often do you charge your player's batteries? once a month
eyeballKid
1) Rio Karma 2) 18 months old 3) internal battery 4) n/a 5) OGG 160kbps 6) Not very loud (25/30 on the player, but with volume controlled by headphones) 7) 2-3 hrs a day use 8) Charge every 3-4 days
I figure I get 10 hours of OGG (I got a lot more with MP3 192kbps) and I usually charge when down to 30-40% full. Pretty rubbish battery really, but as my player is there to handle the daily commute only I can live with it.
shahedz
1) What player do you own? ipod 20gb 3rd gen
2) How long have you owned it? 20 months
5) What format/bitrate do you use most? itunes i thinks its 128
6) How loud do listen to music on your player (1= Very low; 10= Very loud) 7
7) For how long do you listen to your player on average each day? 1.5 hours
8) How often do you charge your player's batteries (be as accurate as you can) -every 3 days
kevH
1. Ipod Video 60gb
2. 3 months
3. Internal
4. N/A
5. 256/320
6. Itunes set louder 4/5
7. 3 hours or so
8. Every 4 days
Have i won Shadow ???? :D
Tunney
5G 60GB iPod
Since release (around 3 months?)
Internal
N/A
320kbps AAC
5, judging by the volume control
3 hours, possibly with some video thrown in
Every day. It sits in its dock charging/syncing when I'm at home. I do the same with my phone, as I tend to forget to charge unless I get into a routine of doing it every day.
C
Cyburn
1) Creative Zen Nano Plus 1GB
2) About 2 and a half months
3) AAA Battery
4) N/A
5) 128-192kbps MP3
6) 6
7) 60-90minutes each day
8) I change batteries every 10-14 days
PJTX100
30Gb iPod vid
1 month
internal
n/a
256K MP3
8 (but mostly take output from the lineout not the headphone)
1 to 2 hrs
It charges each time I plug it into the car head unit, which can be 4 or 5 times a day.
Maidenpriest
Over to you ...
1. Sony hd5
2. Since Aug 05
3. removable, i also have a spare living in my fridge!
4. Spare battery is about 3 weeks old, i am not sure whether to rotate batteries
5. Atract 256
6. I have unlocked the volume, when listening with earplugs just under halfway to max, speakers or car just under max
7. About 4 hours average, i can listen at work for 8 hours
+ with speakers i usally lose a bar after that long.
8. for on average an hour a day via usb when messing about on the pc, this keeps it topped up!
(My Hd5 never seems to need charging i go on the pc once a day it is connected via the usb and this seems to keep it topped up, apart from the initial charge i have only charged it with the mains charger once when on a two week holiday, i use it for an average of 4 hours a day, i use atrac 256 format and play it mostly on shuffle with 5 hour aprox playlists!)
Phil
Miniholic
60GB iPod Video
Since late November 05 (3 1/2 months)
Internal
N/A
128kbps Mix of AAC & MP3
5/6
2 or 3 hours
Voted every five days, although I often need to resynch in between to add tracks, so it is sometimes more frequent. Only had it die on me once in the time I've had it.
KiNeL
Sorry for plagarising MAIDENPRIEST but my specs are so similar I thought I'd save the typing...!!!
1. Sony HD5 (Black & no cracked buttons)
2. Since Aug 05
3. Removable, I also have a spare living in my fridge!
4. Spare battery is about 6 months old, I am not sure whether to rotate batteries
5. MP3 128 & some Atract 192
7. About 4 hours average, I can listen at work for 8 hours
8. I plug it in to the charger virtually every time I come home so thats at least once a day and I generally leave it overnight. Bottom line is that it last's so long I no longer even think about it.
Had a smug chuckle last year when I went down to NZ and even though I took my spare battery I never needed it during the 23 hour flight whilst sad trendy iPodders (of which there were several) were probably dying somewhere over the middle east..tee hee hee....!!!
Maidenpriest
2. Since Aug 05
I know i have had these experiences too! i really feel sorry for them for not seeing beyond the looks of an ipod and status of having one, to buy something good!
funkyg
60GB ipod video
Since November 05
Internal
N/A
192 MP3 (LAME encoder)
When connected to car, 7. Through headphones, 5.
About 3 hours
If I don't put any new music on, about every 4-5 days. But if I have any new music to upload I'll just leave it to charge.
