  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
Battery-Free 3D glasses
keerti Ranganat
Are Battery free 3d glasses actually as good as they are calimed to be? Will they really give me a wide angle for viewing Tv and that too without any flicker?
Jason Shouler
These are normally referred to as passive or circular polarized glasses.
They produce ZERO flicker and very low cross-talk (very important when watching 3D).
The horizontal viewing angle is indeed very wide (as far as 3D goes) but the vertical viewing angle is quite narrow. For this reason it's not a good idea to mount passive sets high on the wall (unless you point them down) and table mounted is probably ideal.
celsius
There is no such thing as battery free 3D glasses.
There are 2 types of 3D glassess - active and passive.
Active 3D glasses need power, and different makes of TV may not be compatible with each other.
The battery free glasses you referred to are actually passive 3D glasses. There are also different types of passive glasses but generally circular polarised glasses are used such as those used in cinemas (real 3D) and almost all of the passive TVs available so far.
Whether the 3D is good very much depends on the TV, not the glasses. Different passive glasses make very little difference in viewing quality.
Jason Shouler
You might think so but it's good idea to question the quality of passive glasses if purchased. I bought quite a smart pair of goggles from eBay but they're inferior to those supplied with the TV :(
I even heard that LG managed to ship some defective glasses themselves!
keerti Ranganat
@Celsius, Jason. Thanks for the advice.
Jason, sad to know your purchase of glasses from ebay has been bad. But there have to be some options avialable apart from those supplied by the company. Any big brands out there for the same?
Shashank Gopal
@celsius, can you please shed some more light on the differrent types pf Passive 3D glasses. Are they really better than their active counterparts?
celsius
As mentioned already, all present passive TV adaopt circular polarised technology.
The other is of course, linear polarised technology which some cinemas adopt.
Therefore the glasses are not compatible with each other.
Fewer and fewer cinemas now use linear polarised screens, but many still remain (e.g iMax).
Therefore the glasses you get from a real 3D cinema can be used with your passive 3D TV (LG/Philipps/Toshiba) but those from iMax cinemas cannot.
Active vs passive is always a debate, you should research their pros and cons, see for youself, and then decide for yourself. My own preference is passive, considering many factors.
Jason Shouler
It was nothing to cry about - they still worked (just not as good as supplied by manufacturer) and we're only talking £5.50 lol.
You can indeed buy quite expensive stylish 3D passive glasses if you really want (as long as you make sure they're circular polarized)
UltiResis
