Battery compatibility
amaclac
I need to replace my battery for my Galaxy S2. The exact model I own is the GT i1900P. What other S2 model batteries are compatible with my model? For example, will the GT i1900 fit? And is it worth buying the high power batteries?
mvf4
Maybe check out the Anker batteries on amazon, not used them for a S2, but I had a couple of their higher powered batteries for my htc for a couple of years with no problems and I believe they list the compatible models in the description
Jay Z
Just stick to standard batteries mate. No point in buying extended power batteries as there isn't really that much difference.
Use Amazon and but a genuine standard battery.
Jay
Sent from my GT-N7100 using Tapatalk 2
