Batt for PSP
Discussion in 'Playstation Forums' started by Steven, Jul 19, 2005.
  1. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,436
    +6,222
  2. plaver
    plaver
    Oct 12, 2003
    2,311
    Bannockburn , Victoria, Australia
    +98
    Note: mAh = a measure of the energy stored in the battery. The higher the mAh rating the greater the amount of energy stored in the battery.
    The rating is how many mA's can be used in an hour so yes you get twice the energy stored, usage will determine if it will last twice as long.
    In other words the higher the rating the better
  3. Tetlee
    Tetlee
    Jan 21, 2004
    19,731
    Taunton
    +4,348
  4. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    I picked up one of these in the states. They are fantastic. Yes in my experience this exteral pack has almost twice the life of the PSP internal battery.
    Whats more it works like a mains charger. So it actually charges your internal PSP battery whilst you are playing (If its flat)
    With headphones I have got over 12 hours use using the PSP battery and this to suplement it. Its pretty small and light as well.
    Highly recommended, it easily increases the PSPs coverage for most long haul flights :)
  5. hughesy
    hughesy
    Jan 22, 2005
    846
    Irish in Oz
    +13
    bought this one and works fine..... Play
  6. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,436
    +6,222
    thanks people
