Question Bathroom speaker help
Discussion in 'Hi-Fi Stereo Speakers' started by vipergrm, Nov 9, 2017.
    1. vipergrm
      vipergrm
      Sep 6, 2005
      3,800
      Belfast
      +578
      Hi folks,
      Can anyone recommend a decent bluetooth speaker for a bathroom? I would prefer a ceiling mounted one if possible. Had a look a the bluetooth mirrors but the ones I saw didn't seem particularly loud and the Mrs didn't really like that idea anyway. Any suggestions appreciated. Thanks!
    2. ShanePJ
      ShanePJ
      Well-known Member AVForums Sponsor
      Jun 20, 2006
      2,180
      116
      Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
      +545
      I would try to look at a more conventional speaker, amp configuration and let the amp include the bluetooth.
      Bluetooth is a very limited with its distance and you've also experienced the limitations on sound quality (amplification in-place of Bluetooth signal).
      It may cost a little more, but the benefits long term will be far more enjoyable.
    3. vipergrm
      vipergrm
      Sep 6, 2005
      3,800
      Belfast
      +578
      You do realise this is for a bathroom? The distance doesn't matter because the room is so small. I don't know anyone who would want a separate amp configuration for a bathroom. It's just for Spotify and radio etc.
    4. ShanePJ
      ShanePJ
      Jun 20, 2006
      2,180
      116
      +545
      Yeah, I also know the issues that bluetooth present for customers. It seems like a perfect solution, but they tend to fall short. Bluetooth is great for one box solution in the corner of a room, kids bedroom, out and about, but they do have limitation. I'm guessing you'll be using your phone to transmit sound to the speakers and control the volume?
      You can place the amplifier out of sight in the bathroom, within reach of the speakers
      Products similar to the Yamaha WXA-50 have the ability to be controlled via a phone app (so you never need to come in contact with them or even see them for that matter). They will have enough power to dive a larger pair of in-ceiling speaker so you are able to please both yourself and your partner.
      Remember, the shower will drown some of the audio out, so if you don't like the sound now, what will it be like when you add the sound of shower.
    5. Konzentr8
      Konzentr8
      Oct 24, 2017
      65
      11
      Plymouth UK
      +17
      A cheap Class D amp with bluetooth for £40-50 and a pair of marine grade speakers , boxes or wall/ceiling mounted
      (£30 +) would do the trick. Try Amazon .
      Nobsound and DROK both make very small bluetooth amps for £ 25 ish and Bassface do a pair of speakers , with brackets , in 3 different colours that your partner might like , model
      SPLBOX and 4RD (red) 4BL (blue) 4YL (yellow) £26.99 pair .
    6. j1singh
      j1singh
      Nov 11, 2013
      122
      London
      +10
      A decent portiable bluetooth speaker which is waterproof and sounds great for the given size and price is the JBL Flip 4.
      It is small yet very well built. You could place it on a shelf and not have the worry of steam doing any damage to it.
      As for sound quality I found this to be the best in its price point against other competitors.
    7. Ste7en
      Ste7en
      Sep 29, 2005
      7,025
      9
      3
      Durham
      +2,867
      I'm constantly impressed at the JBL Flip speakers. My kids have had the Flip 2s, Flip 3s and they are getting the Flip 4s in their stockings at Christmas.
      You can pair them for stereo and you can link multiple devices. They are also waterproof.
