Bathroom LCD
Mr_Wistles
Evening,
Does anybody have one of these?
I understand how you fit them I am curious about how you go about hooking up the sources?
Any advice is welcome.
Mr_Wistles
Ahhh Mr Dragon, good evening.
So say I mount it on the far wall at the end of the bath, if I wanted to hook it up to a DVD player, media player etc... Would I have to run the cables etc in the wall under the floor and to wherever the source may be?
Are the speakers built in? Or are they mounted separately?
Also any recommended makes? Could you give me some links?
hornydragon
Yep
depends on the model
cheap ones are cheap and not great, expensive ones are good but cost £1,000+ what sort of wall is it?
hornydragon
Mr_Wistles
Cheers,
So it has the back box, I then run cables to that and out to another room where I have the dvd player etc??
Where are you based?
hornydragon
Cheers,
If only it was that simple, the Back box is to seal the enclosure to meet IP rating the connections are normally about a foot long and fit through a rubberised slot in the box and hang down to be connected to the sources (a pain in a brick wall)
We can deal with installations all over the country if you fill out the contact form here Wired Life Contact Us we can get in touch and discuss your requirements
