Bass reflex ports - where to buy in U.K. ?
Discussion in 'Home Cinema Speakers' started by Koosnaff, Feb 19, 2001.
  1. Koosnaff
    Koosnaff
    Jun 1, 2001
    79
    9
    Kent, UK
    Hi All
    After using WinISD, I have calculated a box size etc for my sub, but am having problems locating somewhere in the UK where I can browse bass reflex ports. So far, the only place I can find them is Maplins, who have a choice of 4, none of which are suitable.
    All suggestions welcome
    Yours
    Paul
  2. NastyButNice
    NastyButNice
    Don`t really know much about them, but have you tried place`s like car Hi-fi shops for bass boxes, might have a selection ?.
    Just idea !!
    Good luck
  3. Ramius
    Ramius
    Oct 13, 2000
    1,071
    Yorkshire
    +307
    I bought mine (4" flared) from Unicar, Leeds, (car audio).
    Some here-
    https://secure.wilmslow-audio.co.uk/acatalog/Wilmslow_Audio_Reflex_ports_53.html
    Flared is preferable as it acks as a larger diameter and reduces turbulance.
    However any tube/pipe will be ok (try a plumbers merchant?) as long as you keep the mach number down.
    I beleive a 4" flared port is about the minumum diameter you should use with a 12" high excursion driver with no more than 300 Watts power.
    Have you a design yet?
