Bass pop prevention
Discussion in 'Subwoofers' started by Kazman, Dec 29, 2004.
  1. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    Hi guys
    I have my PC Ultra connected to a BFD, when switching off the BFD the PC Ultra does the old bass pop, this makes the wife jump, and she has asked me to see if it can be rectified? Any ideas peeps?
    I do get worried that the pop may damage the sub/driver too, am I being paranoid?
  2. recruit
    recruit
    Kazman - the best way to stop this is by not turning the unit off, i never turn any of it off it has been on since i got it nearly a year ago.
    John
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    As the BFD isn't really designed for low frequency use in the same way as AV receivers are, it might not have muting capacitors on the output to prevent the bass pop. If that's the case I can't think of any way of rectifying it without some major surgery to the BFD, when I get back to Bath and buy the right cables I'll have a look myself.
    Do you get the same pops when the sub's connected directly to your 7400?
  4. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    Nope, not when connected to the SR7400 directly, I think you may be right though, may not be possible.
  5. BH_
    BH_
    put the ultra off first, and then bfd :)
  6. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    The back of the ultra is too awkward to get to, think i'll just leave the BFD on.
  7. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I got a couple of little pops then one day got a massive one,now i turn the sub on after the bfd.I like to keep the bills down and switch everything of at night.
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    It's just the downside of using a BFD I suppose, I certainly hadn't even considered it before.
    Mods, this thread might be better in the normal Subs section, I don't really think it's turned out to be SVS specific. That is if you don't mind Kaz :)
  9. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    Fine by me if it is moved mate :)
    Will leave the decision to the mods :D
