Bass-Management on a DVD-player with SACD/DVD-Audio
Discussion in 'Blu-ray & DVD Players & Recorders' started by arnthelene, Mar 16, 2003.
  1. arnthelene
    arnthelene
    Hello!
    I wonder if it's important with bass-managenent on a DVD-player which plays SACD/DVD-Audio?
    I have a Marantz SR-7200 receiver where you can specify if I have small/large speakers and subwoofer ++++
    Do I need advanced bass-management on a DVD-player to achive good sound?
    Best regards,
    Arnt, Norway
  2. russraff
    russraff
    Aug 1, 2000
    2,414
    Newcastle
    +63
    I think you will find that the speaker settings on your Marantz will be ignored when you use 6CH/8CH inputs. At least they are on my harman/kardon. As you can see on my sig. I have a Tosh 520 and it's bass cutoff frequency is a very high 120hz. This results in boomy DVD-A playback, with the sub enabled. Therefore, because the Tosh doesn't have good bass management, I have to disable the sub in order to get good sound.
    Russell
