Basic TV size question
Discussion in 'General TV Discussions Forum' started by michaelab, Jun 5, 2002.
  1. michaelab
    michaelab
    May 20, 2002
    528
    Lisbon
    +10
    I know that a TV's display size (in inches) is measured across the diagonal but how does the measurement system work for 16:9 TVs? Do they still measure the 4:3 diagonal distance or do they measure the actual diagonal of the 16:9 screen?
    Michael.
  2. Squirrel God
    Squirrel God
    They measure the actual diagonal for 16:9 TVs as well. Hence a 28" widescreen TV doesn't have the same vertical height as a 28" 4:3 TV.
