Basic setup for my plasma
Discussion in 'Plasma TVs Forum' started by John Langton, Apr 12, 2005.
  1. John Langton
    John Langton
    Now I know every plasma set up is different but has anyone got settings I could put into mine so I can get a better picture than the factory standard. The thing Im worried about is my brightness being to bright and reducing the life of my plasma. Any help appreciated
    John
  2. John Langton
    John Langton
    Not one answer? Also to add to this post after two years I cannot believe how stupid I am! I have just discovered the FINE MODE I cant believe the difference. At first you think the picture is too dark but then your eyes get used to it. If you put it back to normal it is way too bright and actually looks horrible. I cant believe Ive been watching my plasma like this for years! Ive probably been burning my retina out! Are there any other obvious things I have neglected about my plasma? I will be getting it ISFed when I can afford it
    John
  3. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    For the record. Brighteness = black level, Contrast = white level. It's the contrast (I believe) rather than brightness that equates to the life of the screen. Small point, I know.
  4. John Langton
    John Langton
    Think it was the contrast then that was too high. Any how I think I will remain in FINE mode from now on
    John
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Fine mode on Fujitsu is like cinema mode on pannys but the difference you saw between normal anf fine the differnece between fine and ISF is as big again..... the other thing to check is connectivity make sure you are using quality connections
  6. John Langton
    John Langton
    You lot are going to think Im a right idiot :( . Ive been using a 10 metre cheap scart lead. Now I know Ive got component BNC connectors and a DVI i will be looking to get a DVD player soon to utilise one of these and make the most out of my plasma
    John
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    get a decent component out DVD player and be prepared to weep at all those lost hours/days/weeks/months and even years of lost PQ......but at least you are learning.........
  8. John Langton
    John Langton
    Should I go component or DVI? I was lookin at the denon 2910 with the DVI output although I know it has both but was wondering what has best PQ?
    John
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    need to demo mate i think DVi may cause you issues than it solves, i would look for a Tosh SD9500/900, Arcam DV88+/89 and denon 2900, but i suggest a home demo of the 2910 and one of the other options
  10. John Langton
    John Langton
    Hi, Horny can you let me know why it may cause me issues. Thanks for all info
    John
  11. dilsher
    dilsher
    sorry John mate - but i gotta do this!!!
    hold on ....here we go... :rotfl: :rotfl: :rotfl: :rotfl:
    better now ta.
    bless ya and at least you can make like you have a brand new Fuji after all!! which is the effect of finding fine mode and buying decent cabling.... Hey u just got an extra 2 years of plasma power now too....
    Regards
    Dil
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    50Hz will be the issue can it handle 576p and 480p at 50 on DVi with HDCP? can it handle 720p @ 50Hz with HDCP can it handle 1080i @ 50Hz if can do all that then a DVi DVD player will work (with upscaling if you want) but uses up your only HDCP input
  13. John Langton
    John Langton
    hmm is this info any good?
      Size:
      28.3 KB
      26
      Size:
      109.4 KB
      24
  14. John Langton
    John Langton
    Looks like it can do 1080i at 50Hz and 720p at 50Hz. 576 at 50Hz but the 480p is at 60Hz
    Not sure if this is DVI or HD so think the best thing you say is to see if a store can loan me a player to check
    John
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    if those are for the DVi input which has HDCP you will be fine (except you are using your only HDCP input for DVD) what a screen can accept on DVi and component, VGA (RGBHV) can vary so make sure they are for DVi, if they are you are laughing..........
  16. John Langton
    John Langton
    Thanks Horny Dragon. Im not sure how I would be able to find out if these are also for the DVI output but I def know that anything through the DVI input is definately HDCP as it states so in the manual. Also you mention as to using the only HDCP input for the DVD player. What else would I use it for? Are you refering to the new HD Sky coming out? If so am I right in thinking I could connect a sky and a dvd player to an AV amp and then run that into the player or does it not work like that
    John
