frenchnes
Hi all,
Sorry for the long post and sorry for the fact it’s a “beginner” post… so probably questions you will have answered dozens of times. But I hope this post will also interest all newbies..
My questions are a mix of how things work and system advices…. (I will number them for easy answer)
First : my objectives :
I am currently listening music on a computer (imac) , and a bose speaker and I want to invest in a hifi system that will blow me away sound-wise relatively to my current poor set-up.
I listen to digital music ( spotify), cds and plan to listen to my vinyls again.
Ideally in terms of budget I would like to spend £2000 max (disappointing I know
). But if adding an extra £500 gives a system twice better I could consider it.
Second : what I understood (or not) :
I am really not familiar with hifi at all. I am still struggling to understand the various “parts”. When I say parts, I mean amp, pre-amp, streamer, dac and probably more.
I understand (and correct me if I’m wrong) that you have “integrated amp” which are amp + pre-amp ?
You have even more all-in-one “integrated amp streamer” (or whatever the right term) that combine the integrated amp with a streamer (or receiver, what’s the difference) ?
1) I am still not sure of the role of the pre-amp ? is it necessary or not ? Necessary in the sense that without it you can’t select sources (phono, cds..etc.) ? Necessary in the sound quality ?
2) I was also wondering regarding Bluetooth : is Bluetooth (if there is any) a part of the amp or the pre-amp ? Do all systems sold nowadays have Bluetooth, and is there a difference in quality of Bluetooth system depending on the different systems ?
3) As said I have a spotify subscription and would like to use Spotify Connect. Would integrated amp enable that or should you have an all-in-one (that I called integrated amp streamer) system or a streamer/receiver ?
4) Now on integrated vs non-integrated : is there a traditional split of reasons why some people should choose integrated amp vs separate system and vice versa ? I was first interested in an all-in one system (integrated amp streamer) but I am worried that a) if one part malfunctions, too bad, b) it limits your upgrade possibilities, c) the whole stuff becomes obsolete faster as I imagine for instance streamer improves quicker than the amp part..? But now in terms of integrated vs not ? As I am not a hifi expert I guess an integrated system would be easier (less parts, less space, less cables and probably cheaper?)
5) DAC : not something I heard of before (which shows my hifi level). Is the DAC in the amp ? in the pre-amp ? I see some are sold as a stand-alone unit, does it mean there are none in some systems or is it a better one that overrun the existing sh*tty one ? Do mid-range integrated amps have a decent DAC system ? is this part a major component in the streamed music sound ?
6) now in terms of advice…. I was overwhelmed by the number of brands, this is just crazy ! And I’m sure there are dozens of great amps with fantastic reputation.. But from what I wrote above , are there a few obvious choices I should consider in your view ? As any newbie, I googled “best amps 2022” sort of things and some names come up frequently like the CXA81 for instance. I guess bigger brands tend appear more frequently in that type of search, but are they decent choices ? or are those sites influenced.. ? Anyway, any advice, suggestion is welcome.
SPEAKERS :
if there are a lot of amp brands, it’s probably even crazier for speakers… range of prices too…
7) the first question I want to ask and I am not sure it makes sense or not : how much would you spend in the speakers in the overall price ? I mean vs let say an integrated amp : same or less/more ? If we take my £2000 example, would a 1000+1000 get me a better sound that for instance 500 on amp and 1500 on speakers ? or 1500 on amp and 500 on speakers ?
9) For those who had recommendation for an amp/integrated amp, what set of speakers would you pair them with ? (because I guess some speakers “fit” better with some amps than others ?)
So that’s a lot of questions, I hope this post is ok for the forum. I have consulted AVforums very frequently for various reasons (TV, outdoor speakers and sound system…) and have always been impressed with the level and extent of knowledge. I hope basic questions are ok !
PS : this is for a small room (about 4mx4m) with 2 doors opposite walls, quite filled with things (table chairs, sofa, books, shelves…). Not sure it’s useful info but I have seen on the form people asking about it to others !
SPEAKERS :
