Question Basic Outdoor Projection Questions
Discussion in 'Projectors, Screens & Video Processors' started by JHWright, May 23, 2018.
    1. JHWright
      JHWright
      May 22, 2009
      41
      I’m looking at the fisability of projecting some of the upcoming World Cup games in the garden. Having never looked into projectors/screens etc. before I’d appreciate some (fairly entry level!) assistance so I have some level of confidence I’m heading in the right direction!
      Garden: it’s a courtyard for a townhouse so it’s small but shady. There is a two storey wall opposite the house so my plan was to hang a pj screen from that wall and project from the house, either from the ground floor or first floor, whichever works better. The distance between house and wall is approximately 5 meters.
      So my initial thoughts are being outside is the glare/light a losing battle? The screen will be fixed to wall so there is no backlight which I assume is a good thing. The screen won’t be in direct sunlight, but if it’s a bright day would this still be an problem? I’m recalling days of my youth trying to watch tele in the garden and it being a complete non-starter!
      Projector: this is where I show my ignorance! All my viewing inside is from my HD Sky Q box. I’ve got boxes in various rooms so getting the source to a projector shouldn’t be an issue. I assume you feed the pj via an HDMI input the same way you would a TV. Can you recommend a make/model that would be suitable for my needs? As this is a temporary set up I’m happy to rent/borrow/buy 2nd hand but need to know what I’m looking for first.
      Screen: again, these seem to vary a LOT! Same applies in that it’s a temporary set up so prefer not to spend loads unless I can get something perfectly suitable for a decent price. I can fix directly to a wall so something that can hang from fixings would be ideal. I’d want the screen as big as possible bearing in mind the projector is no more than 5 meters away and the viewing distance will be less than this.
      Sound: is this output from the projector or from the source (Sky Box)? I’ve a decent Bluetooth speaker/standard Sonos set-up/Bluetooth soundbar etc. so assume these would do the trick.
      Budget: as this is a temporary set up I don’t want to break the bank. But as always I’d rather pay a bit more and have something that works rather than get some cheap Chinese stuff off eBay and find it unusable. If I could do everything for no more than £200 that would be good. As I say, happy to hire/buy second hand and don’t need the best stuff out there, just something that will do the job well. Would consider buying new to sell on second hand later if that’s the way to do it.
      Appreciate any comments/help.
    2. mick24402400
      mick24402400
      May 12, 2015
      212
      46
      great yarmouth
      +128
      You would be lucky to get some thing in the 2k range to light up in an out side enviroment
    3. mick24402400
      mick24402400
      May 12, 2015
      212
      46
      great yarmouth
      +128
      Unless you plan to record world cup matches and show after midnight
    4. Joe Fernand
      Joe Fernand
      Jan 20, 2002
      28,157
      The Borders
      +3,374
      Unless all of the games you wish to view are very late in the evening I'd forget it and make the most of your indoor setup.
      Joe
    5. Goodmane
      Goodmane
      May 26, 2011
      249
      46
      Manchester
      +135
      The Epsons are bright. A used tw3200 or even better 3600 might be found for a few hundred pounds used. But as stated above you are going to struggle unless it's dark outside. I've seen some people use medium grey screens mixed with silver paint to help defeat ambient light. You'd need a short throw distance (reducing screen size options) and a new lamp on full dynamic brightness probably, and as stated it would need to be dark -or at least dim- outside.
      It might be fun but I think it would be more fun for movies in a big garden to entertain children at a bbq or something.
    6. mb3195
      mb3195
      Dec 27, 2007
      1,512
      2
      116
      Deeping Gate, Peterborough
      +1,454
      As above, you’ve got no hope of offering anything decent for x10 of your budget.
      It’s a great idea in theory, but outdoor projector setups have a number of issues before you can even consider offering a semi decent picture or sound.
      Stick to a BBQ outside and watching the games inside.
    7. Goodmane
      Goodmane
      May 26, 2011
      249
      46
      Manchester
      +135
      As above.
      But if you have low expectations on quality, size and ambient light, it looks like you can get a workable picture with paints or some kind of screen. Mix 50% of dark grey emulsion and reflective silver paint shouldn't look much different to this I would think?
      OLED TV LIKE OUTDOOR BLACK PROJECTION SCREEN...
    8. Joe Fernand
      Joe Fernand
      Jan 20, 2002
      28,157
      The Borders
      +3,374
      I'll be showing the UEFA Champions League tomorrow night to a group of around sixty at our local Community Centre with my 5,500 Lumen Epson EB-G7000 series unit (similar set up attached) without the blinds closed the image would be washed out at the time the game is played.
      As above if you have a big bright projector you can try constructing an ambient light rejecting screen - if you can borrow a Projector you can have a play around of an evening to judge the size of image you will require for the expected audience size.
      Joe
    9. MikeTheBike2010
      MikeTheBike2010
      Oct 24, 2010
      195
      46
      Brighton
      +131
      We do this a couple of times each summer.
      I have an old roll down screen I attach to the garden wall.
      Old surround amp goes into the greenhouse / lean to which has power and feeds a 5.0 selection of old speakers around the audience who bring their own chairs.
      Pic is provided by an old “1000” Panasonic LCD PJ (it dates from around 2002, is standard def and doesn’t owe me anything.
      We wait until dusk then pop on a DVD and 7 foot film delights the invited audience. Despite the ancient bulb a perfectly viewable picture is visible from dusk onwards?
      Most difficult decision is which film to show!
      So far
      Blues Bros
      Back to The Future
      Cinema Paradiso
      Grease
      Have all gone down well.
      Hoping to show Hunt for Wilderpeople and the Proclaimers ones this summer.
      Go for it, it’s great fun.
    10. Joe Fernand
      Joe Fernand
      Jan 20, 2002
      28,157
      The Borders
      +3,374
      'We wait until dusk then pop on a DVD and 7 foot film delights the invited audience' - that is the tricky bit with big sports events, you can't 'Time Shift' unless you lock everyone indoors for a couple of hours and ban all Media Feeds :)
      Joe
      PS 'The Commitments' is another good Movie option.
    11. MikeTheBike2010
      MikeTheBike2010
      Oct 24, 2010
      195
      46
      Brighton
      +131
      Absolutely right.
      Great film suggestion (once went to see Akan Parker interviewed in Brighton but has forgotten that one). One of the benefits of everything being SD and out of date is that any film we want to source on DVD costs peanuts on eBay!
    12. Joe Fernand
      Joe Fernand
      Jan 20, 2002
      28,157
      The Borders
      +3,374
