Basic HC amp advice needed
dUnKle
Whats a good quality well made nice sounding HC amp for around £100 to £120
5.1 needed - along with at least 2 digital and 3 analouge inputs
Anyone recommend anything
Badger0-0
Bit low I'd have thought.
Yamaha do a base model (357???) but I think it's £150 plus.
Second hand maybe a better bet.
If volume isn't important, how about a secondhand Videologic digitheatre????
Loud enough for my 20x9 room :smashin:
Not stunning, but ok. Doesn't have the required inputs though.
EDIT 357 is £112
http://www.digitaldirectuk.com/products_moreinfo3/index.asp?product_id=8709&sa=KELKOO
Worth a nose.
It isn't going to be rubbish either.
Knyght_byte
Richer Sounds had a Yamaha amp going for a £100 i think.....for the money your spending you wont be unhappy......
