Basic facilities but quality picture
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bernard Barnett, Feb 17, 2003.
  1. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Dear All
    I want to buy a multiregion player but have no need of DVD-A, SACD, prog scan etc as I shall only be playing movies into my CRT TV. Is there such a thing as a player that gives a top-flight picture but is nevertheless basic in other respects? I've done quite an extensive search here but couldn't find an answer. Budget not important. Any suggestions would be much appreciated.
  2. MattDX
    MattDX
    the toshiba SD220 is supposed to be the best in it's class under £200. Richersounds do them multi region for £120. I'll be getting one in the next week or so to go with my new TV.
