Basic editing software
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by jan3826, Mar 27, 2005.
  1. jan3826
    jan3826
    I own a Panasonic NV-GS70 digital camcorder. The camcorder came with no editing software, can anyone advise of any preferably "free" or trial software that will allow me to make basic editing functions. I only want to edit family recordings on my pc and not go into competition with speilburg!
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Movie Maker 2 is a great program and very easy to learn & use. However it is only any good to you if your PC is running Windows XP. If not then it wont run on your PC. If you are running XP then this will do everything you need to capture & edit your video. You will need additional software to get the footage off the PC and onto a DVD etc.
    A great resource for learning MM2 can be found Here[/url
    If you are not running XP then other options include software from Sony, Pinnacle & Ulead. Take a look on their web sites as they all offer a free trial download of the software. These software packages will offer far more options than MM2, but they do cost money which you may not need to be spending.
    Good luck with finding the right software. Let us know how you get on and feel free to ask any more questions that you may have.
    Mark.
  4. jan3826
    jan3826
    Thanks Guys- will try later. :smashin:
  5. jan3826
    jan3826
  6. jan3826
    jan3826
    Sorry guys- all is in order. Dense as i say!!!
  7. hao
    hao
