Basic dvr- questions
Discussion in 'Blu-ray & DVD Players & Recorders' started by teresalondon, Dec 31, 2004.
  1. teresalondon
    teresalondon
    hi could anyone please answer these questions
    when recording to dvr- i know you can only record once but can i record a bit at a time until disc full?
    also if i record to dvr- or dvdram disc can i put these on the computer and re edit them? and how is the best way
    many thanks for anyones help
    teresa
    x
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yes you can as long as you dont finalise a disc (how you do this depends on the machine you are using) once disc is finalised you cant record to it anymore
    To edit on a computer you will need a PC drive that can read RAM discs and some editing software have a seacrh as there is loads of info on this around
  3. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    Yes. You can record multiple programmes to each type of disc.
    Yes. There are hundreds of programmes that let you do this although you'll need compatible hardware - checkout Rasczak's Guide for advice. One of the more popular is TMPG MPEG Editor - available here. However if you get a DVD-RAM machine (or most DVD-RW ones) you can edit on there just as easily (if not more so) than on a PC.
  4. teresalondon
    teresalondon
    thank for the answers mr horny
    can dvr- be edited also on pc?
    im thiking of geting a new pc sony vaio
    best wishes
    teresa
    x
