Basic DVD player - which one?
Discussion in 'Blu-ray & DVD Players & Recorders' started by SwindonTim, Jan 27, 2003.
  1. SwindonTim
    SwindonTim
    Jan 27, 2003
    I want to buy a simple DVD player to connect to my Toshiba 28" Nicam TV. I don't want home cinema, just a regular DVD player. Should I look any further than the Sony DVP-NS305?
  2. SwindonTim
    SwindonTim
    Jan 27, 2003
    This must be an easy question - someone let me know a viewpoint here - thx....
  3. Squirrel God
    Squirrel God
    It's a great player. I have the previous model, the DVP NS-300. I don't think you'll be disappointed :)
  4. hutchingsp
    hutchingsp
    Welcome to the world of "they're all about £120, buggered if I can decide" :)
    Don't know about the Sony, but the usual suspects worth considering at that sort of money are the Toshiba SD220 and the Pioneer 350.
    My suspicion is that if you brought the Sony you'd still be delighted, the amount of choice just gives more room for "did I do the right thing"...
    regards
    Paul
  5. juboy
    juboy
    That's where my £120 would be.
  6. SwindonTim
    SwindonTim
    Jan 27, 2003
    Thanks for all your advice...
    Would there be any reason to go for the 405, or am I going to get all I need from the 305?
    How does the Panasonic DVD-XV10 compare - is this just designer gear vs good performance?
    Thx...
  7. Will Hunting
    Will Hunting
    my friend has the 405 & it has a nice remote control with number pad that 305 doesnt have
  8. damtom1
    damtom1
    The Toshiba 220 is blinding player for the money.(Will match up with your TV aswell:cool: )
  9. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
    The 405 has extra features including MP3,VCD and DVDr playback. The 305 is a good player but the 405 is better well worth paying the extra few quid!!
    Oh yeah it also has digital out which the 305 does not have.
    Dal :blush:
  10. Squirrel God
    Squirrel God
    Oh yeah the 305 does have digital out (coax).
  11. SwindonTim
    SwindonTim
    Jan 27, 2003
    I think I'll go for the Toshiba 220 - one final question - will the child lock allow me to prevent my toddler from opening the disc tray (and trashing it)....thx
  12. richard plumb
    richard plumb
    Jan 27, 2002
    14,465
    Windsor
    +1,044
    no, he can still press the button and swing from the tray :(
    BTW, Toshiba SD220 is £99.99 at richer sounds (R2 only). Plays MP3, VCD and CDR.
  13. Geoffc10
    Geoffc10
    please be aware that the 220 has probs with r2 of chicken run, so looks like a firmware upgrade is needed.Who knows what other titles dont work.
  14. Will Hunting
    Will Hunting
    i thought 220 had problems with matrix too
  15. P.Smith
    P.Smith
    It did but this was fixed with a firmware upgrade.
  16. shoestring25
    shoestring25
    Feb 2, 2003
    3,789
    essex
    +388
    so is it right that the toshiba 220e multi region dvd player from richer sounds now has a firmware upgrade to v1.5 and can now play the matrix properly?
    can anyone who has one confirm this?
    cheers:confused:
  17. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    I can confirm that RS had v1.5 even 2 months ago when I purchased mine from them. If you ask them they will confirm it before you buy.
