Basic AVR250 / DV79 setup
Discussion in 'Arcam Owners' Forum' started by stickybz, Jun 16, 2005.
  1. stickybz
    stickybz
    Am I right in assuming that by setting all speakers to large on the DV79 and all to small in the AVR250, the sound will only get processed once (at the amp) leading to less DSP degradation??
    Thanks in advance :lease:
    arcam avr250/dv79, kefQ7/2QDS/9c, wharedaleSW250
  2. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    The size settings on the DV79 refer only to the analogue outputs. When you use these outputs you will be going in to the DVD-A input on the AVR250 and thus have no processing done in the amplifier.
    When playing DVD's using the digital output into the DVD input of the AVR250 then the speaker size settings are on the amplifier.
    In both cases only one set of processing is happening.
    DVD-A processing in the DVD.
    DVD video discs processing in the amplifier.
  3. stickybz
    stickybz
    aha, thanks!!!! :thumbsup:
