BM08
Well............ was it action packed? or was it a soppy rom com (too many ladys!?) hehe!
The GX speakers sound fantastic and are a big step up over the RXFX range.
Good luck with the fixings and enjoy the sound once you are set up and ready to go!
The GXFX are heavy speakers.
My walls are drywall so I bought some anchor locking bolts/screws that open up on the back of the dry wall and give a good fixing.
Bought them from Homebase and are rated at a load bearing of 25kg.
Hi Dave, and great to hear you like my cinema setup!Nodular, really like your setup. We seem to have some similar ideas when it comes to home cinema! I've been thinking about starting a thread of my own here but haven't gotten around to it.
Not sure if you like 3D or not (I enjoy it in small doses) but the family wasn't up for a movie last night so I treated myself to Gravity in 3D. The LS-10000 did a really terrific job, although you can't knock the source material either! The Denon also excelled with the soundtrack. Now, I'm still running 5.1 so I can only imagine what it would sound like with your setup! But even with 5.1, it was impressive.
Anyway, great hobby we have, wouldn't you say?
Cheers,
Dave
Take a look at a couple of other other Skins for Kodi, as they present a much better view of movies than default...Been ripping some of my blu Rays to HD and have started using Kodi.
What a great interface.....love it!
Thanks for the info with regards the skins.Take a look at a couple of other other Skins for Kodi, as they present a much better view of movies than default...
I'm partial to Aeon Nox (Add-on:Aeon Nox - Kodi) or Amber (Add-on:Amber - Kodi)
HTH
Gav
What HD boxes do you have,and how do you download movies from kodi onto a hard drive mate?
I have Kodi how did you get the blu ray covers to show your Kodi I be honest I am pretty thick when it come to do this sort of thing as am new to thisBeen ripping some of my blu Rays to HD and have started using Kodi.
Where did you get the funky side/under/over tables from? The glass ones next to your Seating positions? I've been looking for exactly that kind of table for drinks!
I'm also in Stockport, with a Victorian semi, also with a cinema basement! Mine however, is the cheap version of yours, and looks nowhere near as nice! ;-) - Onkyo NR646, Wharfedale Pacific Pi-20s, Pi-Centre and Pi-10s, Monitor Audio BXW10, BenQ W1070 3D and a Samsung BD J7500.
Will you be going UHD?
