mswarren
Established Member
I'm finally about to start building my (semi) dedicated cinema room. I need the room to be my home office too, so there needs to be some considerations for that, but otherwise it's all cinema.
The room is 3.5m X 4.8m, an it's in the basement of our townhouse so it's pretty dark already, and underground so no chance of annoying the neighbours. Frankly it's crying out for a dedicated room, so what choice did I have?
Kit List (So Far)
The Plan
I'll be using the room long and narrow to get the best throw for the projector, and better speaker positioning. the sofa will end up almost in the centre of the room.
The rear corner will be for a small desk and wall mounted monitors, and some office storage.
I'm hope to construct a lighting pelmet around the outside of the room for down-lights, LED strips to colour wash the ceiling, rear surrounds, projector mount and cabling.
Decor will be as dark as is acceptable, and a sumptuous carpet.
I'll try to keep the progress updated, and take lots of pictures.
How the room is now:
Kit List (So Far)
- Optoma HD30 - We have done some dry runs and it seems really very capable.
- Denon AVRX-2000 - I have another in the lounge, and you can't beat it's bang for buck
- Eltax Symphony 6.2 Fronts and Centre - These are my ageing speakers, now in their 4th house currently on duty in the lounge but will be moving here to go for a sleeker look in the lounge
- Monitor Audio Bronze Di-Pole Surrounds.
- BK Monolith
- Pansonic 3D BluRay - BDT130
- XBMC - Probably on another Acer Revo as I've got two others, and they just plain work.
- Sky+HD
- Rear surrounds - Need some in-ceiling rears, likely some Monitor Audios
- Screen - Projector will throw 120" comfortably in this room, so looking for a fixed screen.
- Cables etc
The Plan
