Sandmansingh
Hello. So I am getting my basement done and then electrician ran 1 speaker wire and looped it for 6 ceiling speakers. So it's 1 cable going to 6 ceiling speakers. I have 2 zones. 1 zone is a side of basement for projector where I have independent speaker wire running so that is fine. I bought Yamaha rvx 1018 receiver and ceiling speakers r regular 40 watt max speakers. They are 8 ohm. From what I gather if I hook up all 6 ceiling speakers then I get 1.3 ohms. If I do series / parelle then I get 2.6 ohms.
Qstn is. Amp is 120 rms per channel. If I hook up 2.6 ohms to amp as zone 2. Will it blow up the amp or will it be OK. I won't be cranking it much. Just Mello music. Will the amp shut off or fry up?
How do I fix this ohm issue.
