Bargain Fuji 2800Z
Discussion in 'Photography Forums' started by Julie Winston, Mar 10, 2003.
  1. Julie Winston
    Julie Winston
    Spotted this deal on Jessops web site and the shop matched it:
    Fuji 2800Z plus the following free of charge:
    extra 32Mb Smartmedia (16Mb fitted)
    Case
    Fuji Card Reader
    £249.99
    Very pleased, exactly what I was after.
    Julie
  2. puc
    puc
    Jun 17, 2002
    167
    +4
    hi
    do you have a link for this? I could only find the bare camera for £249.
    thanks
  3. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Puc, didnt want to pee on Julies fire but you can get a far better deal by getting a price ffor this camera on www.pricerunner.co.uk for example just the camera
    http://www.camerasdirect.co.uk/desc.asp?id=2852 is £181. That leaves £70 for the extras.
    Then getting jessops to price match (they will do this with a print out of the price and the phone number of the supplier - must have camera in stock and be uk sourced).
    All the extras can still be got cheaper with the lowest price on pricerunner. Ie card £30 for 128M and card reader £6 from www.scan.co.uk, camera case from jessops £10. Leaving you £25 better off
  4. Julie Winston
    Julie Winston
    That's what happens when you finally make the purchase - the price drops! I checked Jessops & the deal I got has gone
  5. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Fraid to say julie that when you first made the entry on here i checked the price on pricerunner and the same deal (£181 was available then). So you could have got that deal then. felt mean posting a reply straight away tho!!
    Jessops are a bit duplicitous in that they have fairly good offers on the wbe but dont go out of their way to tell you they will price match in the store against any website that sells uk stock and has the camera in stock.
