Bargain 49/50” for occasional viewing - bedroom
Discussion in 'What Is The Best TV For You?' started by DodgeT, Feb 11, 2018.
  1. DodgeT
    DodgeT
    Jun 30, 2007
    2,054
    63
    Stoke on Trent
    +171
    As above, after a cheap but decent 49/50” smart tv for the bedroom.
    It’ll be used for a bit of cartoons for my boy in the mornings and a bit of cartoons at night for me (family guy etc).
    Viewing distance is about 2.5m, so guess doesn’t matter if FHD or 4K.
    Any cracking bargains out there to recommend? Budget ideally less than £400.
    Thanks.
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,003
    +4,356
    Best value TVs at that size will be either the 49" Samsung FHD models or the 50" Samsung/Philips UHD models.
    With the UHD models look at only the 50" since to get a good panel, not 49.
    Guide: My best value TVs, 2017 Edition
