PhilGrover
Hi guys,
I hope someone can help me!
I have a the above PJ and have been playing with a Toshiba HD-E1 HD-DVD player that I wanted to connect via component.
I got a picture but a very dark one which I have since discovered is due to the tri-level sync signals in the video.
This is fine as I have a tri-level sync card fitted.
The problem is that in the manual it says to use input 6 for component on Port 4/5 and input 8 for component on Port 4/5 with tri-level sync.
However, when I select input 8, the PJ just asks for a second digit.
What am I doing wrong?
James brought a D-Theatre deck over when he installed the projector and it worked fine.
Regards
Phil
Regards
Phil
