Barco Vision 1600 HD problem
Discussion in 'Projectors, Screens & Video Processors' started by Doki, Oct 13, 2004.
  1. Doki
    Doki
    Hi folks,
    my Barco 1600s won´t start anymore. It´s HTHD-led on the G2(?) module is lit for a second, fades out and goes on again and so on. You can hear a "ticking" in the same interval. I think it comes from the power supply. The Scan Fail led on the controller unit is always on.
    I already checked all fuses, but they seem to be fine, and trying pull out and push back all boards, but nothing happened...
    Can you help me tracking down the source of the problem ?
    P.S. Sorry for the wrong english, I learn it :blush:
  2. JMPremier
    JMPremier
    Sep 3, 2004
    145
    The scan fail is what will be bringing the hthd (high tension hold down) led on. If the unit detects a scan fail fault it holds down the ht so as to not burn the phosphor with the electron beam due to it not moving the beam.
    As for where the scan fail has actually occurred that will take quite a bit of diagnostics.
    Are you competent at electronics?
    John
  3. Doki
    Doki
    Yes, a little bit. My own profession is electronic artificer.
  4. Doki
    Doki
  5. Doki
    Doki
    Or I need a service manual for this projector.... Somebody?
  6. JMPremier
    JMPremier
    Sep 3, 2004
    145
    I have been trying to find a sercice manual for it so that I can talk you through the circuits/components to check, but havent found one yet. Failing to find a service manal for it the best tat I would be able to do is give 'generic' advice on which components to look for and what to test for.
    John
  7. Doki
    Doki
    OK, thanks...
    Here in Hungary not a simple thing to servicing this machine. The dealer told to me, he send this machine to BARCO, and repair in the factory. This is very expensive to me. I think so...
  8. JMPremier
    JMPremier
    Sep 3, 2004
    145
    Doki, if you go to here and email him to see if he as a manual for the 1600.
    Maybe one of the more knowledgeable members will be able to tell us what other projectors use the same circuit boards.
    John
  9. Doki
    Doki
    Thanks, John. I send an email, but the list is not to be located this manual. Waiting for reply...
  10. Doki
    Doki
    Him don't have this manual. Unfortunately....
  11. JMPremier
    JMPremier
    Sep 3, 2004
    145
    Is the 1600 modular with plug in cards like the newer projectors or can you access the circuits while the projector is powered up like the older barcos?
    You need to be able to measure voltages while the projector is powered up and it is virtually impossible with the modular chasis.
    John
  12. Doki
    Doki
    The 1600 is modular. I find a service manual to 1209, the power supply is the same, like 1600. Leastwise first look...
  13. JMPremier
    JMPremier
    Sep 3, 2004
    145
    The scan fail circuit around the h and v circuits works by putting a small voltage onto the base of 6 bc549c transistors (one each for red green and blue horizntal and vertical. When the transistors are switched on, as they should be if the scan circuits are functioning correct, they pull a +17v low. Bringing the +17v low on this part of the circuit then allows another trasistor to switch yet another one that clamps a pin of a multivibrator to ground locking down the eht.
    The problem you have is because of the modular design to test for the voltages around the transistors you need riser cards to give you access to the circuis while powered up.
    Because you havent got a riser card you are going to have to look for component failure. You are lucky on this side though because all of the circuits are replicated 3 times so you have means of comparison, you will be able to check the resistance across the junctions of the transistors and compare them with the other 2 transistors on that part of the circuit.
    Another thing to check are the safety resistors they will normally be marked on the board as SRxxx rather than just Rxxx, also the ones that are likely to fail are the ones below about 10ohm again these are eisily tested insitu.
    All of the info above is 'generic' and should only be done if you feel competent, I also cant be held responsible if you end up electocuting yourself and burning your house down :D
    John
  14. Doki
    Doki
    Hi John, I'm in the hospital :D It's a joke... :laugh: I starting up a measuring.
  15. Doki
    Doki
    Hi all
    My Barco working again. Some transistors going out in the PSU and deflection board, I will change this out, and voilá! Thanks for help!
    By
  16. Doki
    Doki
    Hi all!
    New problem: my Barco's green tube is dead :( If anyone to know some green tube for this model, please write here. Thanks
    Doki
  17. Doki
    Doki
    So, the tube part nr.: Sony SD-146A, Barco part nr.:R7626325K. If anyone know this type used tube, please help me.
