Barco to HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by m0v1em4n, Oct 27, 2001.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    829
    Derby
    +49
    Hi all,
    Does any one know where I might get a VGA to RGBs cable to connect a Barco 708 data CRT up to a HTPC, is this a special lead,
    Any help would be appreciated
    Steve
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,664
    7
    167
    Birmingham, UK
    +10,546
    You need more than a lead. The barco has 4 inputs, right?
    R,G,B and S. The S - sync - input is combined horizontal and vertical sync.
    The PC outputs separate syncs.
    You need a box to electronically combine the sync signals.
    Basically the box has a D-plug input connected via a VGA lead to your PC. The box has 4 cables coming out - R,G,B and S.
    Barco's boxes are over £100.
    Roland at B4 may be able to supply a used one. Or you could find the circuit diagram from the internet and build it with maplin parts costing about a fiver.
