Barco/Sony tubes...HELP!
Discussion in 'Projectors, Screens & Video Processors' started by Cam, Jul 27, 2003.
  1. Cam
    Cam
    I have been offered a set of perfect tubes from a parted out Sony 1272Q for a very attractive price. Would they fit a Barco BG801S?
    Any help appreciated.
    Cam
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Phsyically they are the same tube but the EHT leads (big red ones) will be too short and the fittings on the end are not the same.
    It is possible to extend them but that old 35,000 volts has a bit of a trick of finding it's way out.
    If it was the other way round you just have to tuck the surplus away.
  3. Cam
    Cam
    Thats a shame, but just my luck! Would you be prepared to do the 'Frankenstein' mod as I am not confident about doing it myself?
    Thanks for the advice
    Cam
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'd be happy to fit and extend the leads for you. but probably can't fit it in untill about the end of August at the moment.
  5. Cam
    Cam
    I'll get back to you towards the end of August.
    Many Thanks
    Cam
