Barco RCVDS 05 switcher
Discussion in 'Projectors, Screens & Video Processors' started by mattmarsden, Apr 25, 2002.
Thread Status:
Not open for further replies.
  1. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,554
    48
    +98
    I have just got hold of a Barco RCVDS 05 switcher with 2 RGBHV input cards.
    I know you can get component input cards for this as well. I think that also with the decoder board it will convert component to RGBHV. Can anyone confirm or add anything to this?
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Excelent switcher but what you want to do may be a bit pricey.
    Component input card is List £195+vat
    Decoder (which IMHO is not brilliant) is List £235+vat
    With the decoder fitted every video input will come out RGBS (composite sync) at 15Khz. Its will not split it to Seperate H & V sync.
    Are you using this with a Barco projector because there may be a better way round this?
  3. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,554
    48
    +98
    No, I'm using it with a Sony G70QM.
    Can the HDTV component board be used with the decoder, and therefore higher resolutions?
    I am thinking for the future for use with an HDTV D-VHS.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    The internal decoder will only work with standard line rate video. Every thing will just pass through. The HDTV card has one diode extral or less than the RGB card.
    What your really need is the Sony switcher or an Extron system 8 switcher configured for sony.;)
Thread Status:
