P
proudx
Is this Normal? When I go into the installation menu to setup the crt and get to the raster centering part of the setup. It tells me to hit enter to center green, When I hit enter to center green "the first one", it moves all three rasters blue,red,and green. then hit enter to center red, then hit enter to center blue. well no amount of adjustments will move the red and no amount of adjustments will move the blue as well. So what I did was used the pots to center the raster on the blue and red tubes to get it to align with the green one.
What is the difference between this global raster shift in the installation menu that seems to shift all three rasters and the raster shift that is in the covergence menus and the raster shift in the geometry menu?
I don't think it is the same raster shift that is in geometry. That raster shift only seems to move green. And it is set to 49 or midposition when my installation global raster is centered at 61width and 60verticle
