Barco Data800 Questions
Discussion in 'Projectors, Screens & Video Processors' started by Orbital, May 15, 2001.
  1. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Hi All :)
    I've recently bought a second hand Barco Data 800 (Cheers Mr. G ) and I'm after a set of manuals for it. I've contacted Barco and they said that they don't have an electronic version so I'd have to pay £25 each (there's two apparently) for the original paper versions. I just wondered if anybody knows of any other source I would be able to acquire these manuals before I shell out £50 for something that my 1 year old son will take great pleasure in drawing on as soon as my back is turned! I've had a look around the web without any success, but I know you guys (and gals) know of sites that I might have missed so I thought it would be worth a post.
    Oh yes another question concerning my Data 800 involves a ceiling bracket. Do you think it would be possible to make your own? I asked Barco about a new on at the same time I inquired about the manuals and they are asking £300 for the original bracket and £750!!!! for a new all singing all dancing one. For this amount I would assume that it's gold plated and comes with a nubile young woman to switch the projector on and off for you!!
    Thanks in advance for all help given
    Orbital
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Do a search at AVS in the crt projector forum and you'll find a post about how to build a bracket for any crt projector from Unistrut.
    It will not be pretty. It will work. You will have to be very carefull about positioning with it.
    I'd expect the £750 bracket will have tilt, skew and distance adjustments like a good unicol one. The unicol one will cost less, but not by much.
    Hope this helps,
    Gordon
