Barco Data 808 (non S)
Discussion in 'Projectors, Screens & Video Processors' started by CRT Boy, Dec 3, 2003.
  1. CRT Boy
    CRT Boy
    Iam looking at buying a used Barco Data 808 (non S) model from a reseller of used CRT projectors. Curently I use a Barco Data 800, should the picture quality look very different to the data 800? i.e. a side by side comparison not be required.
    And also anything to look out for on this model in terms of faults that are not obvious?
  2. zap
    zap
    May 19, 2001
    261
    U.K.
    +3
    I had a BD800 & moved up to a BG808 and I can tell you it makes a big difference the picture is just so much better you will not regret making the change.
  3. CRT Boy
    CRT Boy
    Thanks, will I be able to see a picture difference when the seller demos the unit to me? I just don't want to buy a lemon!! Any buying tips on the BG808?
