Barco data 600 problem
Discussion in 'Projectors, Screens & Video Processors' started by AJ666, Oct 9, 2003.
  1. AJ666
    AJ666
    When I select the internal pattern generator on my data 600 all I get is all three guns lighting with a blank (bright white) screen. Anybody help with this one ?
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Have you got the White video contol box or an RCVDS 400 connected to the 25pin socket?
  3. AJ666
    AJ666
    Yes - I have an RCVDS unit. I think my only option is to use an external source for the pattern. I can make one on my computer and use that. Thanks Roland for taking the trouble to reply.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Using an external source will give you a much better line up.
    I don't trust the internal gids on any projector for anything more than a basic setup.
    It would be usual to get a full white screen without the 25pin connector engaged.
    ~sorry my brain won't go far enough back for one these.
