Barco Data 600 picture distortion problem
Discussion in 'Projectors, Screens & Video Processors' started by ralphot, Apr 6, 2005.
  1. ralphot
    ralphot
    Feb 24, 2005
    36
    My Data 600 is slowly getting up to perform.
    I have now a problem with pincushion distortion that I do not know how to adjust. You can see it clearly on the picture.
    The left vertical edge is really vertical and straight, the right is slightly sloping and the top and bottom are really curved.
    How to adjust? The installation manual doesn't give much on this or I can't find it.
    It is a 4:3 screen, 170 X 128 cm, throw distance 285 cm, floor mounted, slightly angled, both projector and screen to get the right 90 degree angle between them.
    In fact, there are adjustment pots for horizontal straight line for each color but they are not sufficient. Even if I adjust the pots to their maximum the lines are not straight.
    Ralph
  2. ralphot
    ralphot
    Feb 24, 2005
    36
    Can it be that I am using a large part of the disply area? Should I make the raster smaller and retract the projector a bit? Could that help?
    Help please :lease:
  3. arbey
    arbey
    Oct 8, 2002
    76
    maybe if you can shift the image a bit in the other direction (shift/ H phase) you can get better results adjusting...
    regards
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    As you say there are pots to adjust the top bottom bow. there should easily be enough adjustment. time to check components / replace boards. I'm afraid.
  5. ralphot
    ralphot
    Feb 24, 2005
    36
    Yes, I suspected that components have some years behind, will check it out. Guess I have to order a service manual now.
    Tnks Roland
  6. diaporama
    diaporama
    can you please take a photo of the switchbox controller on the remote socket at the rear of the projector ?
    i have a barco 650 data but i dont have this parts :-/. i want to make one myself but i need a big photo of the both side of this controller... i think on the 600 and the 650 it's the same.
    thanks
  7. ralphot
    ralphot
    Feb 24, 2005
    36
    Hi diaporama!
    I can give your better than photos, find here:
    http://www.area51.org.il/~bagaren/manualer/barco/Barco Graphic 400 Service Manual/
    Item 19 - Control Box! Then you can build it yourself from the schematics!
    Good luck!
    Ralph
  8. diaporama
    diaporama
    yeeeeeeeeeah
    thank you!!!!!
    i've searched this manual since 3 days :)
    Merci!!!!!!!!!
  9. ralphot
    ralphot
    Feb 24, 2005
    36
    You are so welcome! The other drawings could be the same for our projectors despite they are for BD 400. I think the convergence for example board is exactly the same.
    Good luck!
    Ralph
