Barco and iscan
Discussion in 'Projectors, Screens & Video Processors' started by skid, Jun 4, 2005.
  1. skid
    skid
    would an iscan ultra be suitable to use with a barco 701, I have read a bit about them, they have all the functions i want out of a scaler, but it only outputs prog scan. I am not sure the resolution is high enough, I was thinking more like 720
    Has any one had experience using one of these with a 701 .
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I would say it would be a perfect match. and 720 would be a good resoloution to run with.
  3. skid
    skid
    thanks roland, am i correct thinking the iscan ultra will not output 720p
  4. crispybig
    crispybig
    Sep 28, 2004
    273
    +6
    You are correct. The iscan ultra is a line doubler, NOT a scaler. It just converts the normal interlaced signals into progressive - and does a good job of it. It will NOT output 720p.
    Can't advise on the optimum resolution for the 701 as I don't know them (yet), but I'm sure Roland does and he says 720 would be good (and I assume better).
    I'm interested myself, as just today I got me a 701 Vision MM to play with.
  5. PsychoDogBeast
    PsychoDogBeast
    Jul 16, 2004
    326
    28
    +36
    Hi there
    I'm running a pretty early model 701, (95) at 1280 x 720 @48/50hz, this seems to be a decent resolution for the unit, without visible line structure. Any higher than this and its out of the projectors bandwidth.
    Hope this helps
    James
