Barco and HTPC
Discussion in 'Projectors, Screens & Video Processors' started by nfordenfield, Mar 29, 2003.
Thread Status:
Not open for further replies.
  1. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    My barco seems to roll the picture with my HTPC, thought it might be the graphic card, but does not do it on the monitor.
    Are there any know issues, I know about the negative sync's.
    I'm hoping that it is a software issue on the HTPC, as it did not do this with John Spicer's HTPC, mind did not do it with mine till I unlocked the drive and loaded dscaler.
    Just trying to eliminate the Barco 1208/2.
    Nathan
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    My money is on the PC
    Drop the resoloution to 800x600 temporaily that should prove it.
    check you are using input 5 and not 4.
    If ypou have another pc/lap top that you can wire in just for now that would help
Thread Status:
