Barco 808s - Raster adjustment
Discussion in 'Projectors, Screens & Video Processors' started by mikett, Jun 17, 2005.
  1. mikett
    mikett
    I am trying to adjust the raster as prescribed in the manuals.
    No matter what I do there appears to be no effect on the raster. In fact to be quite honest the image of the raster as shown in the manual does not apply as the whole surface is illuminated.
    This projector has been "worked on" and has new tubes or at least the blue and green.
    I do not think some basic adjustments have been done, so possibly this is the problem. I am thinking about the stig adjustment, but I believe you need a highly trained gorilla for that one,
    Mike
  2. crteaman
    crteaman
    May 18, 2004
    428
    +6
    Hi Mike, the term gorilla certainly fits me mate, sounds like you are struggling, where about's in the UK are you as I'm alway's whizzing up and down dear ol' blighty.
    james
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Do a search in this forum I did quite a detailed method of doing it.
  4. mikett
    mikett
    I think, I hope I have got the rasters OK. Just the top corners which arguably are not perfectly right, I think on the red.
    Thanks for the help.
    Mike
