Barco 808s - Monochrome picture
Discussion in 'Projectors, Screens & Video Processors' started by mikett, Jun 17, 2005.
  1. mikett
    mikett
    Having failed at everything else, what better than to restore confidence with a DVD.
    A beautiful picture of Lawrence of Arabia blowing up trains. Small problem - just a green picture. This was with component input so I tried to see if there was full colour with composite - no picture at all.
    DVD player checked OK (thru Scart). Cables OK. Projector showing all colours during installation.
    I am looking for a little success here any ideas.
    Mike
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Scart does not output component only video and RGB. Unless you are getting the sync from the scart. I thibk you are feeding composite video into the green.
    Try taking the green cable and putting into the video select 1 for video and see if you have all the colours
  3. mikett
    mikett
    The mention of Scart is a bit of a red herring. I am using a Pioneer 737 DVD Player which has component output. As I was only getting a green monochrome picture I tried composite with no avail.
    I wanted to prove that the problem was in the projector rather than elsewhere. So I checked the cables for continuity and checked the DVD player by removing and connecting it to a TV. That is the origin of the Scart comment. I guess it would have been sensible to have checked out the composite via the TV but a Scart cable was to hand.
    Mike
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Either your dvd player is not set to output component, or you are using input 5 instead of 6.
  5. mikett
    mikett
    My 5% knowledge about memory blocks resolved that one.
    Mike
