Barco 808/ CINE 8 review?
Discussion in 'Projectors, Screens & Video Processors' started by Rob, Nov 6, 2000.
  1. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Does anybody know where I can find a review of the Barco 808 or Cine 8 projector? I am thinking of buying a second hand 808 but can't find any reviews anywhere.Is the Cine 8 the same kind of spec?
    Cheers.
    Don't think you can, Know you can.
  2. Guest
    Hi Rob,
    I believe the cine-8 is one of the 'home' versions of Barcos. The 808 is more of a corporate machine- ie fully loaded and spec'd, so extremely desirable as a home cinema projector if a little bulky. The two are probably similar in performance, but I'd imagine the 808 will handle higher resolutions, XGA etc and have more inputs. Check out this Barco forum for more (probably biased) info: www.tawforum.com
    under the Customer Service forum, then Used Barco & Electrohome forum.
    FYI- I'd buy an 808 tomorrow. Awesome!
    Simon www.si-tec.co.uk
    [This message has been edited by Barco Man (edited 07-11-2000).]
  3. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Thanks for that Simon. I'll give it a try!
