GlennR
Established Member
I have a Barco 801s which I'm experiencing intermittent problems with the picture stability. The picture seems to try and collapse/flicker from the sides in. This is probably no coincidence that a noise coming from the direction of the EHT unit at the rear of the projector seems to be in sync with this fault. The noise coming from the EHT area fluctuates dependent on the brightness of the picture being projected
Any recommendations or advice as to how the problem can be resolved?
If the EHT transformer needs replacing - is this an easy precess and what price is a replacement part?
Regards
Glenn
Regards
Glenn
