Barco 801s doesn't start help me
Discussion in 'Projectors, Screens & Video Processors' started by jago, Apr 27, 2005.
  1. jago
    jago
    i' ve a little problemq with my Barco Graphics 801s
    It doesn't start
    Spec:
    Rear led is RED
    On control board stand by led is ON and Projector Cycle is flashing
    if DIP SWITCH 4 is ON stand by led is ON, ERROR LED is on
    on the right of the SMPS there is a yellow led on (under screen and focus control) , the yellow led is the (-17)
    I've controlled the fuses of the SMPS but are ok
    if i press some button of the remote control the led RCU and ERROR alternates on and off for some seconds
    some advice?
    thanks
    Luigi
  2. arbey
    arbey
    Oct 8, 2002
    76
    Hi Luigi,
    can you tell us more about the scanleds that can be found on the right side of the barco (standing behind the unit, which is on table)?
    The first board from the right has the scanleds on it (seven yellow and one red led).
    The yellow leds should be on, the red led should be off.
    good luck
  3. jago
    jago
    i' ve only the (-17) yellow led on all other all off even the red one , there is a stiker near
    the projector is off in stand by there is no EHT and fans noise
    it is not responding at start up even with dip switch 4 ., with it the Prj should start with only ac power but i' ve only an error led on control board
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I think your power supply is dead.
    but try this
    Try removing the EHT control card at the back of the projector. that's the black board (with white writing) held in with two silver slotted scews just next to the quadrupler in line with the fans.
    (this will effectivly disable the EHT circuits)
    Start the projector now see if all the lights come on.
  5. jago
    jago
    i did it Roland
    but nothing of various
    the same behavior
  6. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Power supply i'm afraid
  7. jago
    jago
    wich one?
    can i control all components of the board to find wich one is fault?
  8. jago
    jago
    and now what can i do?
  9. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    You will either have to get your powersupply repaired or find a replacement.
  10. jago
    jago
    can i repair it with the help of a TV tecnichian and the service manual?
  11. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Has to be worth a go
