Barco 708 crt projectors
Discussion in 'Projectors, Screens & Video Processors' started by fatrich, Aug 9, 2001.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Hi<br />Does any one out there own or had experience's of one of these projectors.I'am thinking of getting a used one from a recommended source but i personally have no knowledge of it.I Have faith in the guy who will be suppling and installing it.it is just back ground information i'am lacking, it doesn't come with a line doubler but i have an iscan will this suffice?The dvd player is a pioneer 737 does this set up sound ok?
    look forward to any response.
    richard
  2. Blade
    Blade
    I saw Jenz's previous CRT which was a Barco 708Multimedia. It was a fine projector sending a nice clear image that at the time was about 7ft wide.
    He was using an HTPC into the Barco at [email protected] Your setup will probably give you a very nice picture but would be improved if you went to an HTPC that could hit the sweet spot of the Barco. Is that an option?
  3. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    cheers blade and chris
    Chris i get a good gut feeling about roland i will be giving him a call next monday to sort something out, do you mind me asking is you dvd fed directly into your projector and do you find you need a line doubler or does your 708 come with built in line doubler.
    thanks again
    richard
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Richard, Chris's 737 has an internal line doubler. He also seems to have an internal one (the limo) and an external one (the iscan).
    I'd suggest that to avoid line structure a de-interlacer/doubler would be a good option with a 708. The Iscan should give excellent results for minimal cost.
    Gordon
  5. ATUL
    ATUL
    May 23, 2001
    41
    london
    Another projector you should consider looking into is Sony G70.
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  7. Operandi
    Operandi
    Richard
    I have not got an IScan. My 708 has an inbuilt line doubler, but I believe that this is bypassed when I feed it with a progressive signal directly from the Pioneer 737. When fed an interlaced signal from the 737 I believe that it utilises the inbuilt line doubler/deinterlacer.
    Others on this forum (Gordon, B4 etc) are better qualified than me to tackle this question technically. All I know, for sure, is that I connect the 737 directly to the component inputs on the 708, sit back and marvel at the quality of the picture! I can see line structure on the picture from about 1 foot away, but as I keep banging the wine glass on the screen, I try and sit a bit further back....
    I've just come back from the cinema (got roped into watching Jurassic Park III - a load of ****) so I'm just about to turn on the 708 to see how it compares. Should be interesting.
    Hope this helps (from a non techie!)
  8. Operandi
    Operandi
    I think my 708mm was the one that Jenz used as I believe that Roland exchanged it for an 808. I use the Pioneer 737 with it now and it gives a great picture. I think the IScan would be helpful for non DVD sources although the Lido seems to work well. I didn't want to go the HTPC route from the ease of use perspective but I imagine that one would give a superb picture with the 708.
  9. Operandi
    Operandi
    Richard
    I watched R2 StarShip Troopers on my 737/708 setup after posting here last night. I didn't mean to watch the whole film, merely wanted to see how this compared with the cinema. After spending a while looking at the blacks, the shadow detail, natural colours etc I soon got forgot about all the hardware and became immersed in the film. Couldn't turn it off and enjoyed every minute of it.
    This is the first time that I have compared THE cinema with MY cinema and what I have created after all this effort is every bit as good, if not better on every criteria - picture quality, filmic experience, involvement, sound. If you achieve this with the 737/708 setup like I have done, then you are as lucky as I am. I really think that this is the way to go, particularly on your budget, and you would struggle to do better.
  10. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Chris<br />i too went to see jurassic park 111 the other night and it was poo !!!
    Thanks for your comments they are appreciated the only way to get a proper review is from people with gear, i think i will go for the 708 that roland is offering and use my 737 and my iscan unit rather then get an internal line doubler fitter it makes for financial sense does any one know if the barco internal line doubler is better than the iscan?
    thanks
    richard
  11. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Fatrich,
    Just spotted a second hand Sony G70 on <a href="http://www.loot.com" target="_blank">www.loot.com</a> for £2000 ono, might be worth a look!
    Matt. <img src="smile.gif" border="0">
  12. Guest
  13. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Nice combo
    I use a BD800 via a Quadscan fed by a 737's component output - Stunning picture.
    <img src="wink.gif" border="0">
  14. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
  15. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
