Barco 708 and Phillips Pronto
Discussion in 'Projectors, Screens & Video Processors' started by the jayman, Aug 25, 2003.
  1. the jayman
    the jayman
    Can I use 808 or 701s ccf file for 708? I haven't found a ccf file which has been created specially for 708.
    If there are differences, can anyone refer those shortly?
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,602
    7
    167
    Birmingham, UK
    +10,467
    You could try them and see. If the codes are wrong you could use the layout but re-program the buttons from your own remote.
  3. mediamogul
    mediamogul
    Jan 25, 2002
    497
    Chatham,Kent
    +20
    Yes you can, i used a 808 file for a 701 it worked fine.I think they are all the same.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    All Barco's will be the same from the 7**,8**,9** 11**,12** and 16** these used PPM type signals.
    The cine series uses RC5 type comands and will require a differnt CCF file.
