Barco 1209s floating image problem
Discussion in 'Projectors, Screens & Video Processors' started by hfunk, Dec 13, 2004.
  1. hfunk
    hfunk
    We've been struggling through the installation of a Barco 1209s. We've resolved a number of problems; our latest is that the image 'floats' - kind of like a screen saver effect, moving generally in a diagonal line till it hits the edge of the projection area, then bouncing off and moving in a new direction. I originally thought there was too much noise in the signal, since I was driving it from a computer 8+ meters away, but using a 1 meter cable does the same thing, using S-video or 15HD->5BNC.
    Any ideas for things to check? Things to fix just on general principle?
    Thanks in advance,
    Harry.
  2. Baggy
    Baggy
    Jan 25, 2002
    1,109
    63
    Burton-on-Trent
    +126
    Barco 1209's have a screensaver type function called "Orbiting".
    Could this be what you're seeing?
    Look for it in the Random Access sub-menu and check it's turned off.
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Check your PC.
    Move the mouse from one edge to the other.
    Orbiting is not a comon board to have on a barco.
  4. hfunk
    hfunk
    The effect is independent of mouse movement or interaction, that is, it's not a screen saver. It just reminds me of that sort of motion. Or the old TV/arcade game where the rectangular "ball" would bounce off the edges of the screen.
    Any thoughts?
    Thanks,
    Harry.
  5. arbey
    arbey
    Oct 8, 2002
    76
    I don't know for sure but this makes me think about 'orbiting' too.
    Do you use the 'powerstrip' program on your pc? 'Cause in 'powerstrip' you can activate/desactivate the orbiting ability. Maybe yours is activated...
    regards
