Barco 1208/2 or 1209, i cant remember ?
Discussion in 'Projectors, Screens & Video Processors' started by simonfinch, Nov 4, 2003.
  1. simonfinch
    simonfinch
    Just about ready to purchase one of these for my recently completed room.
    Can somebody give me some idea of a fair price for one of these machines as i may have the chance of one from work.
    i intend to use a htpc to drive it.
    I believe it has iris 2.
    How can i tell if it will be worth the money ?
    Many Thanks
    Simon
  2. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    1208/2 with decent enough tubes is worth 3-4K, 1209 with decent enough tubes starts at about 6k I reckon.
    I run the 1208/2 through an HCPC and the picture easily beats my old TV, I got mine for £1900 but there is wear on the green tube which is only visible on the edges in bright scenes. I reckon I'll hang onto this 1208 and get replacement lamps in the future, very happy with the picture quality.
    P.S - If buying a 1209 you'd better be sure the tubes are ok because if you have to buy them you might have to sell your house :eek: :)
  3. Paul D
    Paul D
    Dec 27, 2000
    2,620
    Manchester
    +391
    Hi Simon!
    You are still welcome to come see my room etc.
    I haven't forgot you !
    I've been quite ill since february, but am now on the road to recovery.
    It might give you a little bit of extra knowledge/knowhow in your search for a CRT etc.
    Paul
