Barclaycard Price Promise
Discussion in 'LCD & LED LCD TVs' started by jimg, Nov 28, 2004.
  1. jimg
    jimg
    Jul 4, 2004
    826
    +58
    As anyone made use of this? I am going to give them a call tommorrow and ask for £400! RGB Direct are advertising the LC-37GA4E at £400 less than Electrical Discount UK where I bought my screen.
    That is unless you know someone asking less than £2234.99? :thumbsup:
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,225
    In a secret location with Jennifer Lawrence
    +7,095
    I haven't yet, but from what I have heard you should definitely be in luck. I know they have a few products which aren't supported, but don't think plasmas are one of them. Just remember to save the page from the website where it is cheaper and print it out before it goes up or disappears. I think this is the proof they want to see.
  3. cerebros
    cerebros
    Dec 27, 2002
    1,187
    38
    Leicester
    +11
    I made use of it. It's pretty straightforward. You give them some details over the phone and they send you a form to complete and return with your evidence of the item being available eslewhere. It's best to print out a copy of both a check-out screen showing the price and also any screen showing that the item is in stock at the cheaper supplier.
