Banna plugs with AVR300?
Discussion in 'AV Receivers & Amplifiers' started by tamthetim, Jul 20, 2005.
Tags:
  1. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    Going to set up my AVR300 at the weekend after moving house and finally finishing the living room.
    Not had it out the box yet, but reading the instructions for connecting speakers cables, says use bare wire or spade connectors only.
    Can you use banana plugs or BFA connectors?
    Thanks, Thomas
  2. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Hi Thomas,
    Yep, you can use banana plugs. You just need to pick out the plastic tips put in the end of the speaker terminals, and bob's your uncle.
    cheers
    Andy
  3. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    Ah................the same as my old Yamaha amp....................took my about a year before i realised that.
    Can't wait to set it up.
    Thanks, Thomas
  4. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
  5. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    BDCSTENG GARETH
    With the Yamaha you actually force the plug through the plastic binder, the hole is smaller than the plug.
    Some people drill it first for a nice finish.
    Cheers, Tam
