Banding issues
Discussion in 'LCD & LED LCD TVs Forum' started by Destino 00, Apr 29, 2019.
Tags:
  1. Destino 00
    Destino 00
    Apr 29, 2019
    5
    Italy
    Hi guys, english is not my primary language,bu i'll try to explain my problem,my phone is an lg g7,i love it in every way,but it had and has today some screen issues.the first time,when i bought it,the screen had a little and quiete invisible light bleed on the bottom left corner,so (im sometimes to picky) i applied some pressure there,hoping to solve the minor problem.unfortunately the only result i had was to make the defect worse... Days later i contacted the center,that fortunately in 10 days changed my screen for free,all was perfect,until some days ago i noticed some banding,is not so visible,but when the screen does a panning on a gray background is noticeable,so im asking you: are there some fixes for lcd banding on smartphones? What should i try? I repeat, the issue is minimal, so theythey wouldn't change my screen this time. Thanks for the eventual answers
    P.s. g7 's screen is amazing
  2. JayCee
    JayCee
    Jan 20, 2004
    23,904
    Lanarkshire
    +2,594
    There's nothing you can try.
    Ask a mod to move this to the mobile phone forum.
    This one (where you've posted) is for Televisions.
  3. Destino 00
    Destino 00
    Apr 29, 2019
    5
    Italy
    Thank you for the answer i've already posted it in the right section
