Band of brothers
Discussion in 'Movie Forum' started by newbie265, Nov 29, 2004.
  1. newbie265
    newbie265
    May 21, 2003
    467
    Rochester, Kent
    +5
    I've looked for comparisons to dts(only in region 1, I think) and 5.1 but found no definative answer.Is te dts region 1 worth shelling out an extra 20 quid for or is the 5.1 version just or very nearly as good?
  2. MC Hammer
    MC Hammer
    Oct 23, 2003
    588
    London
    +18
    Without starting a DTS/DD debate imho it clearly is.
    I can hear a difference & not just that it's louder.
    Totally agree on other DTS discs there is no difference & on others suffers Lyp Sync.
    I actually got the R1 Tin version & the subsequently the R3 Korean version .
    The Military limited version on the R3 is superb with all that is with it.
    However, with the discs themselves, the menus & actual difference on the soundstage is very marked to say the least !
    Hence I now have my R1 tin in the R3 military pack !
    Also believe that the R2 doesn't have the "Field" menus that are on the R1 package ?
    Certainly the R3 didn't.
    If you liked/loved the series the £20 difference for a R1 Tin version is well worth it imo.
  3. newbie265
    newbie265
    May 21, 2003
    467
    Rochester, Kent
    +5
    I've never actually seen the series but love Saving Private Ryan and anything WWII.I'm having a great new system installed( In my sig) and want to get the discs that will get the best out of it.
  4. MC Hammer
    MC Hammer
    Oct 23, 2003
    588
    London
    +18
    I liked SPR but this is better imo.
    Not action all the way & slows down on that score towards the end.
    However a lot of character development obviously over 6 discs.
    Out of all my DVD's this is probably my Fav ?
    The sound on the action sequences are top notch imo.
    Worthy of showing on any high end system & in certain parts the sub will likely blow out your windows !
  5. newbie265
    newbie265
    May 21, 2003
    467
    Rochester, Kent
    +5
    My Svs will like it then, :D
  6. elcid
    elcid
    For some reason I haven't heard the DTS soundtrack (will try soon), but even the DD track kicks major butt! :eek: :smashin:
    You ough to hear the scene where the Rangers jump off the B-29s; one can almost "feel" the anti-craft "flack" at various levels of altitude right in one's room! :eek: Of course, the two SVS B4-Plus subbass units help make the listening a truly frightful experience... :eek: :rolleyes:
    -THTS
    "...hi, my name is Frank...and am an SVS bassaholic..."
